JD 350 Dozer Standard Shifting Pattern
Brent
08-25-2001 19:54:20
I have a 1970 JD 350 Standard Dozer, and there is no shifting pattern on it anywhere. I have found
reverse, and I think 2nd. But it will not go into
I think 1st, which may be straight up from reverse. I was told, that the problem may be in the forks, or springs? I think I found 4th. But all the way to the right and down, I think is second. But coming staight up from second, it wont go in either. Could this be a fork, or spring, or something that may be repaired from taking the tranny cover off?
Steve B
08-27-2001 09:33:36
 Re: JD 350 Dozer Standard Shifting Pattern in reply to Brent, 08-25-2001 19:54:20
Brent,
Straight forward, almost out of the selector is 1st. To the Right and straight forward is 2nd.
Paul
08-26-2001 05:17:55
I have a 350 and straight back from reverse is 2nd and in the front pattern is reverse over to first then over to 3rd. Back towards the seat 2nd up from reverse then over to fourth
