John Deere 555-B transmision
Gerald Bennett
12-22-2004 07:57:29
after running my 555, maby half a day when the oil is warmed up, it doesn"t want to back up. it seems to catch then let loose, it dose this several times, than sometimes it hold and back up, some times it won"t. This happens mainly when I"ve been working in extreamly down hill angles. Any information would be greatly appreached. THANKS>
TN FARMER
12-24-2004 20:11:39
 Re: John Deere 555-B transmision in reply to Gerald Bennett, 12-22-2004 07:57:29
JON IN MA IS RIGHT! THE TRANNY IN A 555 LOADER OR DOZER IS JUNK !!! I HAD ONE AND THE TRANNY COSTS ABOUT 5 GRAND OR MAYBE EVEN NOW MORE. I GOT RID OF IT AND BOUGHT A CAT 941B .
Rusty toys
12-22-2004 19:13:04
Hello Gerald,I had one of those,and worked on others,those machines give trouble on the clutch shaft slip-rings,the rings are lose in there grooves,also the charge pump can get worn to the point that oil preasure is low when hot,with a gauge you should check main trans press when it is cold and again when hot,good place to start,E mail me if you need more help-----Joe.
Gene D Hanson
02-10-2006 13:13:44
 Re: John Deere 555-B transmision in reply to Rusty toys, 12-22-2004 19:13:04
Hi I seen on the the discussion forum, you said you had worked on John Deere 555.I was wondering what you had to do to fix it when you had loose clutch shaft slip rings.On the one I have the shafts seem alright but thier is a groove in the collector where it sits over the ring. The rings are wore some but I have not been able to find any specs.Also John Deere has a oversize kit on the rings but they say that they are for machining the shaft but not the collectors. They do not seem to know much more than I do anyway the guy I talked to.Thanks Gene
Jonathan in MA
12-22-2004 17:19:53
First ensure the oil levels ok..then when its running good...dig a large hole and drive the machine into it...fill in the hole and don't look back...eventually you'll thank me for this !!...
remove the filter canister and look whats inside..
its usually a combination of worn parts in the transmission and worn parts in the steering clutches...all total...verrry expensive...and lots and lots of labor...usually....
