Cat D-7 17A wet clutch adjustment
andy R
01-01-2005 21:37:58
Last fall my clutch was slipping some on a D7 with a wet clutch. I took the cover off yesterday and easily figured out how to tighten it up. WOW - they built that mechanism in there to last forever didn't they!!!! Found the two bolts that clamped the adjustment from turning. Loosened them. Turned the adjustment clockwise some. Clutch now snaps in and out with force. QUESTION IS ----- How much snap or pull (force)should it have when properly adjusted? I think at one time someone said how many pounds of force it should take. Can I actually use a spring scale to measure the force? Should the clutch be hot or is cold OK. Seens like when the dozer is first started it is a little hard to get into gear anyway as the gears want to grind. When it gets warm it shifts easier. Also, can anyone tell me what those little gears in the clutch case are operating? They are on the right hand side. Thank you. andy
hector gemme
02-11-2005 04:56:33
 Re: Cat D-7 17A wet clutch adjustment in reply to andy R, 01-01-2005 21:37:58
HI I HAVE SOME USE D7 PARTS
Bob/Ont
01-01-2005 22:05:03
Andy the spec is 30 Lb pull on a fish scale. Once you get it right you can do it by feel after that.
Later Bob
andy R
01-02-2005 07:32:23
 Re: Cat D-7 17A wet clutch adjustment in reply to Bob/Ont, 01-01-2005 22:05:03
Thanks Bob ... I think you helped me with the clutch issue last fall. I had forgotten exactly how many pounds of pull you had said. I assume this is with a cold clutch?? Thanks again. andy
Bob/Ont
01-02-2005 07:41:41
 Re: Cat D-7 17A wet clutch adjustment in reply to andy R, 01-02-2005 07:32:23
Shouldn't make much difference Andy.
Later Bob
