931 Catepillar Track Loader Steering Clutch Help
DKMiles
01-02-2005 06:05:28
Re: 931 Catepillar Track Loader Steering Clutch
Hello everyone, I need your help ! When I back up and press the brake the the right track locks up, left side doesn't. When I'm driving forward and apply the brake the left side locks up, the right doesn't. I started having a problem when I couldn't get it to steer properly, when I push the left steering clutch it won"t steer on one side. Hopefully one of you has resolved this same problem and could share your resolution with me. Thank you so much !
Bob/Ont
01-02-2005 07:40:30
 Re: 931 Catepillar Track Loader Steering Clutch He in reply to DKMiles, 01-02-2005 06:05:28
First off what serial # is it and do you have wet or dry clutches?
Later Bob
DavidKMiles
01-12-2005 07:30:59
 Re: 931 Catepillar Track Loader Steering Clutch He in reply to Bob/Ont, 01-02-2005 07:40:30
Thanks for the response. The 931 track loader has a dry brake and the serial number is 78U1 & up. Since my last post I checked the lines to make sure they was clear, removed the cylinder and performed a test under pressure to make certain it was working. Under (air) pressure the rod coming from the cylinder worked. However, when installed on the track loader it doesn't work when I push the right brake/clutch. I can't figure out why the rod that comes from the cylinder doesn't work ( hit the yoke) when I push the right brake/clutch. Any idea's??
No signs of any leaks anywhere !! Checked springs all are fine.
Buddy
01-02-2005 15:06:08
Serial number is a must !!! Need those numbers so we can point you in the correct direction the first time .
DavidKMiles
01-12-2005 07:42:54
 Re: 931 Catepillar Track Loader Steering Clutch He in reply to Buddy, 01-02-2005 15:06:08
Serial # 78U1 and up for Cat 931 track loader
