What A-C Tractor Engine Is The Same As 'M' Crawler
StuckRusty
01-02-2005 07:59:10
I'm looking at purchasing a M crawler. The engine is stuck. The most obvious repair is replacing the manifold. If there are other tractors with this engine it will help broaden the search.
Jim in Michigan
01-05-2005 06:24:13
 Re: What A-C Tractor Engine Is The Same As 'M' Cra in reply to StuckRusty, 01-02-2005 07:59:10
They are right,,its a U engine,,I have a M that could use a carb,,,,Jim
Rex (AZ)
01-04-2005 17:15:01
I have two M'sThe engine is the same as most U and uc's early u's had a contonental engine .Okieboy over on the unofficial allis site can get all the parts you need.
StuckRusty
01-04-2005 19:00:05
 Re: What A-C Tractor Engine Is The Same As 'M' Cra in reply to Rex (AZ), 01-04-2005 17:15:01
Thanks Rex, I'll check with Okieboy. At least now if I happen upon a derelic U (FAT CHANCE!)I will look to see if it has a good manifold.
george md
01-04-2005 19:18:23
 Re: What A-C Tractor Engine Is The Same As 'M' Cra in reply to StuckRusty, 01-04-2005 19:00:05
Stuckrusty, If you don't find a manifold , there is a good possibility i can repair that one . Send me a picture of yours showing the damage . Below is a link to a web site sowing some repairs, follow the link in the site to a sequence of repair steps.
george
Andy in Manteca
01-03-2005 19:48:25
I just bought an M crawler (orchard). Needs a water pump but runs well. I heard the water pump from a U works, maybe other parts transfer?
However a U is equally as rare.
37 chief
01-02-2005 21:35:44
To my knowledge The Model M engine is only used in your tractor. You would be better off fixing the one you have. If the pistons are stuck I would take the engine apart and clean the bore. Stan
