plz help bulldozer help needed
adam smiths
01-07-2005 23:54:11
hey can anyone give me a quick layout on how to run a bulldozer?like how many levers and wht they do?mabye start up process and any other tips on first time user.i have one i can play with but need a quick run down on how to drive it.thanks a million
old
01-08-2005 17:20:03
 Re: plz help bulldozer help needed in reply to adam smiths, 01-07-2005 23:54:11
First off what type of dozer, make a big differance on how they work. Second off they are not toys, you can get hurt or hurt others if you don't know how. Third if you really want to learn buy an op, manual and or find some one that will teach you.
BobMo
01-08-2005 16:45:22
If I were you I'd stay away from it as I read your question you may not be to mechanically astute and will probably hurt your self..... .
thejdman01
01-08-2005 13:41:00
my advice would be to find a website as well with a picture of a track and the componets labeled so you ahve an idea of what each component is and waht you are looking at when you check them. (idlers rollers etc etc.) most tracks have the same components just different numbers and sizes. i dont know of such a site mabey somone else does but im sure there is one like it or one out that and you should at least familiarize yourself with the components and visually check them for wear sloppyness even if you dont tackle the repair yourself or it is someone elses machine at least know the components and what your looking at so you can either fix it or alert the proper person.
Billy NY
01-08-2005 10:14:20
Definitely need a MFR. and model to give some insight on the operation of a crawler, specific to what the levers do.
In generic terms after you check your oil and coolant and any other fluids that may need checking, and you know the machine is ready to run, make sure the trans. is in neutral and the brake is locked if so equipped before starting, and also check that the throttle is not wide open. The blade should be lowered to the ground. Reason I mention the above is for a first timer, you need to know about safety, heavy equipment has no conscience as to who it runs over or what limbs it will take. Don't even think about working in the woods around trees or doing any clearing until you are properly trained and have a Roll Over Protection Structure ROPS over your head and if new enough, hook the seat belt up, if you go over a hump you can get launched out of the seat. See if you can find an experienced operator to show you the ropes and leanr the safety, get the operation manual for your machine and READ IT CAREFULLY.
I'd start off in a wide open area, keep anyone watching you in view at all times and away from the machine, these are not toys in any way shape or form, if something goes wrong, you do not have the experience to react fast yet.
With that said, relax a little, start off with low throttle raise the blade and gently put it into gear, it's either a powershift or a direct drive with a standard trans. move the machine by letting off the clutch or increasing the throttle, it should have pedals for brakes, test those and stop the machine. Then try the 2 longer levers which are the steering clutches, pulling on one should lock up one track or cause one track to resist, which turns the crawler, you have to get the feel for the machine you have, there could be foot pedal steering or even small little levers like on a Case 450. You need to take your time and check out the controls slowly, I know Caterpillars the best, but have run most others Case, Deere, Komatsu, Fiat-Allis, they are all different. An experienced operator will really be your best bet, but if you are like me you can learn quickly, I recall just what it was like the first time I went to start pulling levers, after some time in the seat, I learned and mastered a great skill. Take your time and remember safety. It's really hard to be specific unless we know the machine you have by MFR and model, but I hope that helps a little. Best of Luck !
JimInOz
01-08-2005 00:19:00
To get the advice accurate,we need to know the make/model OR post a pic.Plenty of advice here.....
stressfree
01-08-2005 05:11:43
 Re: plz help bulldozer help needed in reply to JimInOz, 01-08-2005 00:19:00
ask someone to show you,dont knock down the barn.most guys will show you for a case of beer.
