JD350: How do I remove the bull gear shaft?
Bob Doss
01-09-2005 16:15:16
The right track on my JD350 loader seizes now and then, so I'm dismantling the final drive to find the problem.
The bull gear feels loose on the shaft, so I want to pull the shaft to inspect the splines.
I inverted the castle nut on the inboard end of the shaft, and beat it unmercifully with a sledgehammer, but it didn't budge.
Do I have to press the shaft out with a bottle jack? Or is there some other trick?
PD Mechanical
01-10-2005 04:54:29
 Re: JD350: How do I remove the bull gear shaft? in reply to Bob Doss, 01-09-2005 16:15:16
third party image
The shaft is supposed to be pressed out. I would suggest removing the entire final if you have'nt already. You can repair it on the machine but this will make things much easier.
