hercules engines
jerry AK l
01-10-2005 22:41:59
Trying to reserect a Hercules GO 130
3 cylander gas engine.
Anyone have a phone number for
Clevite/Dana Corporation?
Thank You
JIM BROWN
01-11-2005 15:59:29
 Re: hercules engines in reply to jerry AK l, 01-10-2005 22:41:59
Call Jerry Biro at 740-745-1475 he owns HERCULES
J. Schwiebert
01-11-2005 08:03:23
Yes & No: No doubdt if in a tractor it is in an OLIVER OC-4. What were you looking for from Clevite. Dana has a 1000 phone numbers. I used to work in there training department.
Jerry AK
01-11-2005 11:41:31
 Re: hercules engines in reply to J. Schwiebert, 01-11-2005 08:03:23
Thanks for your reply. It is an OC46. I need bearings, -30 mains-40 rods, that is what it took to clean up the crank, I have another crank that may clean up at 20 under.
I should have done a bearing investigation before crank work. I need a phone number to talk and see i these bearings are still available.
Thanks
mike_in_md
01-14-2005 09:56:17
 You have to check your block # in reply to Jerry AK, 01-11-2005 11:41:31
It's located in front of & below the manifolds.
IF you have A GO130 you have small rod bearings
IF you have a GO130H or GO130X8 you have large bearings.
Call Zimmermans & get a shop manual (if you don't
alread have one...) It's one of the best manuals
I've seen...
Link
J. Schwiebert
01-11-2005 12:44:38
 Re: hercules engines in reply to Jerry AK, 01-11-2005 11:41:31
You are going to laugh at this. I have no idea what bearings you need as not all of them used the same size crank. The ones with the larger crank are harder to find. I know the Clevite bearing guy too.
