International TD 340 Steering clutches
eddietude
01-11-2005 19:43:11
Hi,
I have a mid 60"s International TD 340, that may need new steering clutches. Any suggestiong on where to get them, and where to have the machine worked on? I'm in the Los Angeles area.
Thanks.
hector gemme
02-07-2005 09:36:59
 Re: International TD 340 Steering clutches in reply to eddietude, 01-11-2005 19:43:11
hi I have some new disc
JimInOz
01-12-2005 22:31:42
Visit RedPower Magazine Forum...plenty of advice there.
KarenM
01-12-2005 09:24:34
We stock all the parts you need. Email me and I'll send you a link.
eddietude
01-13-2005 18:12:41
 Re: International TD 340 Steering clutches in reply to KarenM, 01-12-2005 09:24:34
Hi,
I e-mailed you but never heard back. Please e-mail me if you have the parts...
glenn pyzak
01-14-2005 10:19:59
 Re: International TD 340 Steering clutches in reply to eddietude, 01-13-2005 18:12:41
eddie I wouldnt waist on karenM from crawler heaven They gave me the runaround for a long time and would never reply to e-mails or phone calls thats why i posted this info.
glenn pyzak
01-12-2005 13:06:00
 Re: Karen-crawler heaven. in reply to KarenM, 01-12-2005 09:24:34
I cant believe that you still tell people to call you or ED.You two never reply to phone messages or e-,mails.I did get an email from ED he was very rude and i never did get the parts i needed
george md
01-12-2005 18:58:16
 Re: Karen-crawler heaven. in reply to glenn pyzak, 01-12-2005 13:06:00
glenn,
I don't know what your problem is , but I
gotten every thing that I asked for . Rollers
for a 450 case , complete tracks for a 977L ,
steering clutch parts for a JD450 , all in
good time and price .
george
glenn pyzak
01-14-2005 10:01:54
 Re george in reply to george md, 01-12-2005 18:58:16
I tried to buy parts from Ed at crawler heaven and all i got was the runaround and a rude e-mail from ED. ED OR Karen now will not return any of my emails or phone messeages.That is my problem I have seen other people at this site with them same problem.Im glad you had good luck in dealing with them.I will gladly email you a copy of ED`S RUDE e-mail if you would like to read it. GLENN
Brad in Wa
01-12-2005 17:57:46
Hey Glenn, Tell me more, thanks
stressfree
01-14-2005 16:18:56
 Re: Karen-crawler heaven. in reply to Brad in Wa, 01-12-2005 17:57:46
never got an email back ether.hey moneys money.
PD Mechanical
01-12-2005 05:19:59
third party image
The TD340 does not have steering "clutches". They use a planetary steering setup with steering brakes.
eddietude
01-12-2005 07:27:31
 Re: International TD 340 Steering clutches in reply to PD Mechanical, 01-12-2005 05:19:59
Ok, so where do I get the parts needed for repairs?
Charlie
01-12-2005 08:39:33
 Re: International TD 340 Steering clutches in reply to eddietude, 01-12-2005 07:27:31
Assuming you"re going to have someone do the work, one possibility is a local Komatsu dealer. They bought Dresser which bought International, and they still have direct access to many parts and often have people familiar with the TD340. Probably most people who work on heavy equipment would also be able to do this. I would make sure that you do not just have an adjustment problem first. To adjust the steering, pull back each lever, and with it back, back off the locknut on the adjuster, and then adjust to give a couple of inches of freeplay in the lever.
eddietude
01-16-2005 17:25:41
 Re: International TD 340 Steering clutches in reply to Charlie, 01-12-2005 08:39:33
Charlie,
The book says to do that, but I'm not sure how that works. I mean, you'd need 3 hands for starters. Also, once the locknut is loosened, the adjuster won't turn clockwise anymore, which I think means it's at it's end, right?
In order to turn the crawler without having the track slip, you have to really pull back hard on the lever.
Charlie
01-17-2005 06:26:27
 Re: International TD 340 Steering clutches in reply to eddietude, 01-16-2005 17:25:41
It is easier with three hands. I tie the steering lever all the way back and then do an adjustment, and keep repeating until I get the freeplay right. But there really are two operations going on when you pull back the lever. First it releases the clutching mechanism and then it applies the pivot brake. You should probably first adjust the brake and then the steering lever freeplay. Both are in the operators manual. This may be all you need to do.
