starter to ring wheel TD -6
Brad in WA
01-13-2005 18:55:06
The starter drive was worn out so now its fixed. New drive and bushings. The ring wheel is rough. It used to start great with the crank.If I put the starter back on but start it with the hand crank, will that hurt the new starter drive? or should I not install the starter and only hook the fuel line and battery until later? I just want to get it started and run it some. Thanks in advance.
hector gemme
02-11-2005 03:57:15
 Re: starter to ring wheel TD -6 in reply to Brad in WA, 01-13-2005 18:55:06
HI IHAVE SOME TD6 USE PARTS
Jim Presley
01-13-2005 19:50:07
Hello Brad. If the starter is installed and you start it with the crank, it won't bother the starter at all, so you are OK. The starter will only engage if you give it juice from the battery.
Jim P
Brad in WA
01-13-2005 20:34:12
 Re: starter to ring wheel TD -6 in reply to Jim Presley, 01-13-2005 19:50:07
Thanks, just wanted to make sure.
