Case 350 C Frame
hankster
01-16-2005 12:27:27
where might i pick up a C Frame for a 78 case 350 angle/tilt dozer? are cracks repairable, will welding hold it?
J Kirsch NY
01-18-2005 14:23:23
 Re: Case 350 C Frame in reply to hankster, 01-16-2005 12:27:27
Hankster---I have a Case450B that had a pretty good crack in the C frame. I would say that welding it would only be as good as the welder doing the job. I had a certified welder--boilermaker fix mine and it looked as good as the day it came frome the factory when he was finished. He took a torch and cut the crack open to a deep V and filled it in with multiple passes. It's done a lot of tough work since then with no sign of a problem. I might add that a good part of the crack was on the bottom of the C frame and the welding was overhead welding. I hope you get as good a result with yours. John
Mark In Mi.
01-16-2005 23:04:58
Hey Hankster-I have a Case 350 (1973) w/ the "C" frame welded up. I bought it that way w/ 9500 Hrs. on it. I don't use it a lot but it does all the pushing I ask of it.
Mark
