hey jdemaris
mud
01-18-2005 09:56:13
email me about the 580ck case hoe with the blown 188 and the spare 207 engine. i have been trying to contact you.
mud
mud
01-18-2005 15:09:38
 Re: hey jdemaris in reply to mud, 01-18-2005 09:56:13
i thought you wanted to sell that backhoe? i posted my address above. you posted here afterward.
stressfree
01-18-2005 16:22:15
 Re: hey jdemaris in reply to mud, 01-18-2005 15:09:38
hes not ready to sell backhoe when hes ready hell let us know.
mud
01-18-2005 18:24:59
 Re: hey jdemaris in reply to stressfree, 01-18-2005 16:22:15
dont figure. he has mentioned it over and again.
oh well, he must have a reason. my money can spend somewhere else. i dont chase but so far.
jdemaris- sorry
mud
jdemaris
01-18-2005 19:29:20
 Re: hey jdemaris in reply to mud, 01-18-2005 18:24:59
You guys are sounding like a couple of old ladies. Geez. First of all - MUD - you posted several times asking me to email you - but you failed to provide your email address in the older posts. I'm not a mind-reader. Go back and look at your posts on Jan. 11 and Jan. 12. So, with no address I stopped paying attention. On Jan. 13, your name MUD was highlighted as if it was linked to an email address - but it comes up as "hidden." So later, in one of your posts, that looks the same, your address is finally linked and unhidden - and I was supposed to notice? Here is my email address - hopefully in plain view. jdemaris@capital.net As to the Case 580CK, it was, and is for sale. It was listed twice on the classifed on this website. I've answered questions about it over and over - sometimes the same questions to the same people every couple of months. If I had a dollar for every person that "was coming to look at it", I'd already have more money that it's worth. So I don't get too excited when someone says they're interested. At this point, I don't care if it sells or not - but again, for now it IS for sale - $2000 - as is, where is. If I get around to putting it together, then it won't be for sale. I already have two running backhoes, so I don't need it. And, I've got two dozers torn apart that I'd rather work on this winter instead of the 580CK. I've been offered $1200 for the 207D engine. If I'd been smart, I would've sold the engine and hauled the hoe to the auction yard. The following is an old, but accurate description of it. I'm in Otsego Co., central New York State - in-between Albany and Binghamton (50 miles either way) and 15 miles from Cooperstown.
Case 580CK diesel wheel loader backhoe. This machine, ser. # 8336306, was being
used daily until the engine blew a rod through the side of the block. Loader-hoe is, I
think, a model #33. Has power steering and hydraulic reverser. The blown engine is a
G188 diesel and is probably repairable, but I’m not sure it’s worth the bother. I’ve seen a
few of these engines with the block patched in the same spot. Please note that the
machine is beat. Loose bushings and pins, crappy welds here and there, steering spindles are
loose. Tires mostly bald. No cab. I pulled the covers off the differential and transmission just to inspect the inside
and all looks clean with no wear evident. Oil is clear, no metal filings or water, etc. Hydraulic pump and coupler look good. The radiator looks banged up but I sent it to
shop and had it flushed and checked for leaks, and it’s fine. I took the hoe and front
bucket off the machine so I could move the machine into my shop - but it is all part of the
deal. That was a few years ago, and it still sits there taking up space with the old engine
ready to come out with about a half hour’s work. Please note, it will take a little work to
get this thing out of my shop and onto a trailer or truck, but I’ve got some heavy
equipment around to do it. I also have a good engine that I haven't found time to put in. It's a little
larger in cubic inches, being a 207D but will bolt in as a replacement. 188D and 207D are exactly the same size externally. It is: Model 207D, serial #4307581 . I bought the engine off the estate of a friend that died 4-5 years ago. He got the engine from a military base down south and was getting ready to use it in something when he died. It came from a 580CK military forklift and is supposed to have low hours on it. It's been in my shop since I bought it. It NOW has a tight spot in it when you turn the flywheel half way around. Maybe a rusted rocker-arm? It turned over fine when I first put it in storage four years ago. Anybody who's serious about buying the whole mess is free to inspect it - pull the head, oil pan, etc. Note - I DO NOT WANT TO SELL JUST THE ENGINE. I've had many offers on it - but once I sell the engine, the rest of the hoe is usless to me - even more so than it is now. Anybody who want photos, I've got plenty I can send by email.
Rod de Ramon
02-24-2005 15:19:22
 Re: hey jdemaris in reply to jdemaris, 01-18-2005 19:29:20
I read with interest another note which you wrote concerning converting a Deere rotary vane swing cylinder into a conventional 2 cylinder swing. I'm looking to do that conversion. Where these kits available through Deere? I called a couple of industrial dealers but they couldn't help me.
Thanks for any info you can give me.
Rod de Ramon
mud
01-19-2005 07:15:04
o.k. then- i thought the 'hidden' feature allowed me to get an email notification from yt - along with your email address in it. that way we dont get spammed to death. am i wrong about that? earlier
posts were just screw ups on my part. check your email- mud
stressfree
01-19-2005 02:52:45
i guess mud we woke up a sleeping giant.jdemaris email me a couple pictures of the hoe if you will.dsarno@epix.net
mud you want the engine,i want the hoe.im 1/2 way between me and jd and you.we haul the machine to my place,i take the hoe off,you take the engine,ill scrap the rest.sound like a plan.dont sound like it pays to restore it just part it out.
agri_con
01-21-2005 03:13:40
 Re: hey jdemaris,wait wait in reply to stressfree, 01-19-2005 02:52:45
agri_con2003@yahoo.com
also would like some pics,please forbid don't scrap that puppy yet,I'm located in Glens Falls NY,so not that far from ya to see it up close.
