Need some oliver/cletrac help
agri_con
01-20-2005 04:17:16
After many picture views I cant figure out what model Im working on.First off my customer complaint was no steering on left side/locked up.Just from veiwing it from outside there must be internal bands.Naturally all sn's are gone,is yellow but not sure if original color,blade push beam is located inside track frame,is gasoline powered/4 cyl,not sure what eng.Nose is squared but also fabricated thru the years.Has side fenders.Rear sprocket is larger than idler,sloping tracks at a downward angel.
Any help with anything else to help me figure out what model this is would be a big help,customer says it a 1947 but not sure from what I've viewed so far.
JerePa
01-20-2005 17:44:31
 Re: Need some oliver/cletrac help in reply to agri_con, 01-20-2005 04:17:16
Call Landis Zimmerman @ 717-738-2573. He should be able to help you.
agri_con
01-20-2005 14:00:04
well took the rear apart today and it appears to be the same as a CASE 350 even the housing,were they known to be the same?
jdemaris
01-20-2005 14:18:18
 Re: Need some oliver/cletrac help in reply to agri_con, 01-20-2005 14:00:04
The small Case crawlers are worked over Terratracs (made by American Tractor Co.) since Case merged with the company in 1957. This includes the 310s and 320s, I don't know much about the 350s. The small Cases, the Terratracs, and the small Cletracs use the same basic three speed transaxle that was made by Clark Co. It uses no steering clutches, just two brake bands with a controlled differential which, under certain conditions, can result with just one track driving. Nice thing, though, there are no clutches to get stuck - and you can change the brake bands without taking the trans. all apart.
agri_con
01-21-2005 03:02:34
 Re: Need some oliver/cletrac help in reply to jdemaris, 01-20-2005 14:18:18
unfortunately the drums are shot and loose on the rivets so had to remove the differential.
marv in minn
01-20-2005 05:55:40
for pics and info,go to Link
