D4 steering clutches
oldtime
09-01-2001 00:50:30
what is the removal order for old D4 steering clutches these ones are frozen and wont disengauge thay are dry type i presume tracks,final drives, then clutches havent workd on a cat before only inter and fowler thanks old time
hector gemme
02-10-2005 13:39:54
 Re: D4 steering clutches in reply to oldtime, 09-01-2001 00:50:30
HI I HAVE SOME D4 USE PARTS
2ulew
09-01-2001 01:06:09
Oldtime, Don't touch those tracks and final drives. The clutches come out the top along with the bevel gear and cross shaft as a unit. You should probably have a servicemans manual for this undertaking but if you don't I can try to email you the required section. My scanner is out for repair so it may be a few days. Regards Lew
seplo2
01-04-2005 13:25:07
 Re: Re: D4 steering clutches in reply to 2ulew, 09-01-2001 01:06:09
I too am having trouble with the steering clutches on my D4. I am getting no response when I pull back on either lever and apply the break.
The dozer has been idle for a year or more. Any help?
