case 580CK transmission problems
paul moon
01-25-2005 22:31:03
anyone have any ideas why the hydraulic fluid in my 1979 case 580 CK transmission turns in to a white milky mess and then i loose drive in just 10 to 15 hours of use. i am using 46 medium hydraulic fluid,
agri_con
01-26-2005 03:56:38
 Re: case 580CK transmission problems in reply to paul moon, 01-25-2005 22:31:03
silly question but is the radiator A/F going down meaning a leak in the oil cooler.Of course thos applies to the shuttle end.Trans axle end has alot of places for water to get in.With drain the shuttle,the converter will hold oil as well as hoses from the filter and cooler,all should be flushed.As far as oil goes I use AW-32 hyd,or ATF in the shuttle,matter of preference I guess
