International TD-20C in Need Of Part
Mario
09-01-2001 19:59:28
Hello: Please Help
I have bought a TD-20-C Interantional Dozer. If took the serial number from the right part of the machine it should be 3280. Can anyone tell me a part number for the injections pump of this machine or if you might know where I can find one please let me know. My other question is that I want to load up on a lowboy but I want to pull with a tractor. Is there something that I need to do to it before I pull it. Please give any advice you can on this machine. Third Question: is this machine 24 or 12 volts. Any information will be trully appreciated.
Thank You Mario
Russ Cadotte
09-29-2001 21:43:59
 Re: International TD-20C in Need Of Part in reply to Mario, 09-01-2001 19:59:28
Hi Mario! That serial no. doesn't look right,they go from 25001 to 27724 so check a little closer OK. 20 c's have a DVT 573 eng. & have a V type or
an inline one on the last ones.You should be able
to drag it onto a lowbed no problem,check the oil
in the rear main frame if you pull it any distance
,the stick is on the left rear of the seat & it takes 10 WT series 3 motor oil.It has a 24 volt - grnd system. Email me if you have any more questions Good Luck! Russ Cadotte
PS-The serial no. is stamped in the frame on the right rear outside above the final drive RC
