JD 310
Hawke
01-30-2005 11:32:16
Anyone know anything good or bad about a J D 310 backhoe.? Thanks.
Roy Suomi
02-02-2005 20:43:49
 Re: JD 310 in reply to Hawke, 01-30-2005 11:32:16
In their day they were a fine backhoe.A 3 cylinder backhoe is a little weak when loading with front loader. Backhoe works fine A 310-A has a 4 cylinder engine. A little more power goes a long way..You might find that an older 310 will have some more leaks than other machines, because of a closed center hydraulic system. This system carries 2200 to 2500 lbs. of standby presure at all times when not using hydraulics. Fords , Case used open center hydraulics, meaning that oil is being circulated all the time without building pressure until you pull a lever. Good Luck with your choice..
