TD9 International Transmission Problem
Larry Vaughn
01-30-2005 18:53:51
I have an International TD9 that slips out of reverse. Does anyone know how to fix this problem? Thank you.
Larry
hector gemme
02-07-2005 03:55:54
 Re: TD9 International Transmission Problem in reply to Larry Vaughn, 01-30-2005 18:53:51
hi you have to change the gear and hy have some and check part number.
Tross
03-04-2005 20:31:17
 Re: TD9 International Transmission Problem in reply to hector gemme, 02-07-2005 03:55:54
I am experiencing the same problem with my TD9 (B) crawler except I can't get it to stay in any gear. When I bought the tractor it was stuck in gear, I freed the shifter by taking off the top plate after I put everything back together. I had it running and everything was fine and all of a sudden it started slipping out of gear and now it will not stay in gear and I can't move it. Does anyone know what the problem may be.
PD Mechanical
01-31-2005 04:42:01
third party image
The reverse slider and or gear probably needs replacing.
