TD 5, TD6 crawler weight
crawlernut
01-31-2005 07:40:51
I would like to get a small crawler for a hobby restoration project. What does a IHTD5 or IHTD6 or IHTD340 weigh with or without a blade? Would you guys with crawler experience make some suggestions on a small crawler as to parts availability etc? Perhaps a JD MC as it would probably be smaller and easier to transport to tractor shows? My location is in SE MO. Thanks, Crawler nut.
Harold H
02-01-2005 16:49:45
 Wts T340, TD340, T5, TD5, T6(s62), TD6(s62) in reply to crawlernut, 01-31-2005 07:40:51
I found shipping weight on other crawlers without blades. T340 6053#, TD340 6342#, T5 5967#, TD5 6122#, later nodel T6 series 62 7954#, TD6 series 62 8700#.
Harold H
TD-5Doug
02-02-2005 09:54:21
 Re: Wts T340, TD340, T5, TD5, T6(s62), TD6(s62) in reply to Harold H, 02-01-2005 16:49:45
Wow, thats weird, my book shows weights for the 340's & 5's exactly 1000lbs less on each one, must be a miss print in the book
Harold H
02-01-2005 17:01:36
 Wt of John Deere MC in reply to Harold H, 02-01-2005 16:49:45
Shipping weight of John Deere MC was 3875 lbs.
Harold H
Harold H
02-01-2005 10:48:12
 Re: TD 5, TD6 crawler weight in reply to crawlernut, 01-31-2005 07:40:51
Shipping weight on TD-6 was 7560 lbs. Blade would probably add close to 2000 lbs. Total estimated between 9000 and 10000 lbs. TD-340 and TD-5 would be lighter but I don't have weights.
Harold H
TD-5Doug
01-31-2005 17:31:17
T-5,TD-5,T340& TD340 weigh 5000 to 6000 lbs, add the blade or loader on top of this.
old
01-31-2005 09:16:12
A TD-6 with blade will be around 10,000lbs or more. What you need is this little Cletrac HG I have its about 5000-6000lbs. Drop me an e-mail if you want more info
Harold H
02-01-2005 16:57:09
 Wt of Cletrac HG in reply to old, 01-31-2005 09:16:12
The shipping weight of Oliver Cletrac HG without blade was 3140 lbs. It was available with 31", 42", 60", or 68" track centers.
Harold H
