Due to the many questions we have received regarding Fiat Allis engine parts we are listing the following general information about Fiat Allis equipment with the Iveco 8065 series engines.FIAT ALLIS ENGINE 8065.04.089 103mm / 4.0550 in piston / sleeve bore size FIAT ALLIS ENGINE 8065.04.095 103mm / 4.0550 in piston / sleeve bore size FIAT ALLIS ENGINE 8065.04.097 103mm / 4.0550 in piston / sleeve bore size FIAT ALLIS ENGINE 8065.24.091 103mm / 4.0550 in piston / sleeve bore size FIAT ALLIS ENGINE 8065.24.092 103mm / 4.0550 in piston / sleeve bore size FIAT ALLIS ENGINE 8065.24.098 103mm / 4.0550 in piston / sleeve bore size These engine options were used in the following Fiat Allis Equipment Fiat Allis 65B Grader Fiat Allis FD7 Dozer Fiat Allis FL7 Crawler Fiat Allis FE18 Excavator Fiat Allis FR10 Loader Fiat Allis FR12 Loaders Fiat Allis FE18 R Excavator ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- - FIAT ALLIS ENGINE 8061.I05.017 104mm / 4.0945 in piston / sleeve bore size FIAT ALLIS ENGINE 8065.05.290 104mm / 4.0945 in piston / sleeve bore size FIAT ALLIS ENGINE 8065.05.295 104mm / 4.0945 in piston / sleeve bore size FIAT ALLIS ENGINE 8065.05.297 104mm / 4.0945 in piston / sleeve bore size FIAT ALLIS ENGINE 8065.25.091 104mm / 4.0945 in piston / sleeve bore size FIAT ALLIS ENGINE 8065.25.092 104mm / 4.0945 in piston / sleeve bore size FIAT ALLIS ENGINE 8065.25.095 104mm / 4.0945 in piston / sleeve bore size FIAT ALLIS ENGINE 8065.25.096 104mm / 4.0945 in piston / sleeve bore size FIAT ALLIS ENGINE 8065.25.097 104mm / 4.0945 in piston / sleeve bore size FIAT ALLIS ENGINE 8065.25.098 104mm / 4.0945 in piston / sleeve bore size FIAT ALLIS ENGINE 8065.SI25.003 104mm / 4.0945 in piston / sleeve bore size FIAT ALLIS ENGINE 8065.SI25.004 104mm / 4.0945 in piston / sleeve bore size These engine options were used in the following Fiat Allis Equipment Fiat Allis 65B Grader Fiat Allis FR10B Loader Fiat Allis FD7 Dozer Fiat Allis FL7 Crawler Fiat Allis FE18 Excavator Fiat Allis FR10 Loader Fiat Allis FR12 Loader Fiat Allis FR12B Loader Fiat Allis FE18 R Excavator Fiat Allis FA120 Crawler Fiat Allis FL10 Crawler Fiat Allis FE18 R Excavator Fiat Allis FR11 Loader ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- ----- This information is very important when ordering engine parts or an engine overhaul kit. There are also differences in the crankshaft bearings sizes and the gaskets. If you do not have the complete engine number that we can use piston and bearings numbers and measurements to ensure accuracy. We hope you find this information helpful. Regards, Parts Supply Co, Contact us at: sales1@parts-supply.com This information is designed for informational purposes only. We do not warrant that the information is in every respect accurate. While every reasonable effort has been made to confirm the accuracy of this information, we cannot be held responsible for problems resulting from errors that may be present. If you notice some thing that may be incorrect or would like to add information, please e-mail:sales1@parts-supply.com
