CASE 580 DIGGER
ALAN SMITH
02-02-2005 12:09:17
HOW DO YOU CHECK,FLUID IN FLUID FLYWHEEL?
agri_con
02-03-2005 03:36:30
 Re: CASE 580 DIGGER in reply to ALAN SMITH, 02-02-2005 12:09:17
If its a straight 580 -(up until C-series) the shuttle oil is checked at the small dipstick-left side of machine below steering column,on trans tube.
AJK
02-02-2005 23:02:59
You should find the filler tube with a dipstick in it on the righthand side of the engine over the starter motor,raise the front bucket,you check the oil with the engine running on low idle,shuttle box in neutral,main box in fourth with handbrake on,fill to the F mark with Case TCH fluid,or equivalent.
AJ
