alternative transmission cooler for case
case5801979
02-05-2005 09:52:01
i would like any idea"s on a different way to cool the hydraulic fluid that runs to the bottom of the radiator(cooler) on my 1979 case 580CK
i feel that the present cooler is not up to the job anymore (FYI the fluid gets very hot and causes the transmision to loose drive and also gets severe condensation problems.)
Question. is the fluid under much pressure? ie can i take a cooler from a car and mount it to the front of the radiator and rely on the fan to drag air past it for cooling?
i may be on the wrong track but do case transmission coolers get blocked up or become inefective after years of use.
are there any ways to check this out without pulling the thing out and replacing it.
