D4 Pony Motor Swap to Electric Starter
Cactus67
02-06-2005 19:00:29
I would like to remove my pony motor from my D4 7U and put a starter on the big motor, I seen one on a D4 but the guy said it was on there when he bought it. Does anybody know where I can get the kit or plate to put in when the pony motor is removed, the starter was mounted in the rear of the motor. There are no holes on the side of mine to mount a starter in. Thanks.
John Newman, Toowoomba, Q
02-16-2005 03:06:49
 Re: D4 Pony Motor Swap to Electric Starter in reply to Cactus67, 02-06-2005 19:00:29
An auto electrical firm here in Toowoomba in south east Queensland, Australia advertises 24V direct electric start conversions from D2s to D9s from $1200 Aust Dollars. Please contact me if you are interested for contact information.
hector gemme
02-11-2005 02:50:52
HI SORRY LATE TIME BUT I NEW ON INTERNET AN I HAVE PROBLEME WHIT THAT MACHINE.GIVE ME TEL.CALL 514-591 1036
hector gemme
02-08-2005 11:24:35
hei if no hole you change bellhousing
Kenny McCulley
02-09-2005 23:17:45
 Re: D4 Pony Motor Swap to Electric Starter in reply to hector gemme, 02-08-2005 11:24:35
I've put two of the 24volt starters on my d4 cats. The first one didn't have the boss on the bell housing so I made a cardbord pattern off my other d4 which was newer and cut the hole with my plazma cutter and drilled and tapped the holes to fit a 4omt truck starter an got the drive from an outfit in Taxas and put it on and it works fine Later on the mag drive went out of the other d4 so I did the same thing to it and it works fine also, You leave the starter drive on as on mine I would have had to take the fuel control housing apart so I just cut the pinnion handle off and removed the starting engine an plugged the water holes an put two OPTAMA 12v batteries where the starting engine was.
Larry Berube
12-09-2005 17:40:12
 Re: D4 Pony Motor Swap to Electric Starter in reply to Kenny McCulley, 02-09-2005 23:17:45
Hi Kenny, was surfing the net looking for parts to repair the pony on my sons Cat D4C. He put extensive repair in the cat, and we have problems starting the pony. Looks like a blown head gasket again. I am interested in learning more on how you did your conversion. If you could furnish us with pictures and a step by step detail, we would be glad to pay you for your information. Larry and Micah in Maine.
Reach me at larryberube@yahoo.com Thanks.
