T-340 crawler
RASCALS rIDGE
02-09-2005 11:31:37
I bought a T-340 crawler a couple weeks ago and have the operators and service manuels BUT in both books it talks about a trammision and hydralic filter but it does not show (if it is a changable filter)where it is located or the number of the filter like it does every thing else could it be possible it is just a screen filter inside I sure could use a response on this if anybody has any idea, even called International dealer and they couldn't tell me
Charlie
02-09-2005 18:13:04
 Re: T-340 crawler in reply to RASCALS rIDGE, 02-09-2005 11:31:37
The filter number is WIX 51139 or NAPA 1139. That gives you the two cartridges and the two gaskets, one for inside the screen and one for the cover.
Charlie
02-09-2005 12:17:00
It"s on the lower right side under the brake pedal behind a plate that is held on by a dozen or so small machine bolts. It"s opposite the hydraulic pump on the left side, and it serves to filter the input to the pump. When you take off the plate, youll see a screen device; the two small filter cartridges are inside. Easily available from NAPA etc and come with the gaskets.
rascals ridge
02-09-2005 12:24:26
 Re: T-340 crawler in reply to Charlie, 02-09-2005 12:17:00
THANKS SO VERY MUCH,YOU ARE A LIFE SAVER PRETTY SAD WHEN THE INTERNATIOAL DEALERS CAN"T EVEN HELP, THANKS AGAIN
J.C. IN AZ.
02-09-2005 21:45:35
 Re: T-340 crawler in reply to rascals ridge, 02-09-2005 12:24:26
T-340's went out of style back in the 60's. Your dealer probably wasn't even a gleam in his Dads eye then.
