TD-14A crawler tractor
jchead
02-10-2005 11:20:35
hi does anybody have a wiring diagrahm for this tractor?thanks
captain_crunch
02-10-2005 22:37:52
 Re: TD-14A crawler tractor in reply to jchead, 02-10-2005 11:20:35
JC
What part you need to know about I have the diagrams but they are hard to understand come over to Red Power Mag I can post pics there and there are lots of people there that know these critters end to end. Including several IH shop men
Brian
jchead
02-11-2005 15:38:14
 Re: TD-14A crawler tractor in reply to captain_crunch, 02-10-2005 22:37:52
thanks guys for taking time to get me the info.about that red power, i have register there, but i can,t seem to get a message sent out. what am i doing wrong? captain;just got this dozer.could,nt get to start,mechanic bypassed the mag. wire from mag to a coil,to a toggle switch on dash to hot side of two 6volt batteries,which are hooked together to make a12 volt. this a positive ground system.have to spray starter fluid in air cleaner to get started. what do i need to do?
captain_crunch
02-11-2005 19:36:01
 Re: TD-14A crawler tractor in reply to jchead, 02-11-2005 15:38:14
JC
Check on carb side of engine when on gas cycle and see if the flipper which is kinda behind manifold it has to pop up to open butterfly in air manifold to start on gas. This is a common problem on TD's Don't know what you mean about coil wire to mag ? The only wire on my 14 hooked to mag is ground to kill mag. But if it will run on starting fluid it must have spark so I suspect the flipper mechanisim we are talking wont start on gas start cycle arn't we
jchead
02-12-2005 07:12:53
 Re: TD-14A crawler tractor in reply to captain_crunch, 02-11-2005 19:36:01
captain; the flipper yo are talking about is locking. on the mag let me get back to you later, will go to farm where dozer is and look this wire hookup again.thanks appreciate the help
captain_crunch
02-12-2005 11:00:43
 Re: TD-14A crawler tractor in reply to jchead, 02-12-2005 07:12:53
J_C
If you want to E mail me I may be able to help you get onto R_P just mention TD-14 so wife don't trash can it babj foster(at)msn.com
Brian
Loren
02-11-2005 19:27:21
Try this link, there's an old board also that's gone to archive only I think. My email's open if I can help.
Loren
02-10-2005 21:07:21
I'll see if I can get someone here that can help. Maybe someone else will beat me to it.
