td14 steering clutches
deweed(TX)
02-13-2005 15:53:30
I've been getting a TD14 going for a guy at work. It supposedly operated when parked about 10 years ago. I've managed to get it running, runs great, but won't move, the PTO spins w/the engine clutch out. Is there any hope that steering clutches just need adjustment? If it needs steering clutches is it time to give up on the old girl? how likely is it that both steering clutches wore the same?
hector gemme
02-19-2005 04:47:36
 Re: td14 steering clutches in reply to deweed(TX), 02-13-2005 15:53:30
hi thaque the power take off plate out and see if the bevel gear turn went master cluch and transmission engage if turne oke you have to taque out stering cluch.I HAVE SOME THANK.
RO
02-15-2005 21:21:07
If I remember correctly, isn't there a plate on the back of the tractor, where the PTO shaft would go if so equipped? By removing the plate, I believe you should be able to see whether the pinion gear is moving the main ring gear. I may be confusing this with another tractor, but you might check it.
PD Mechanical
02-14-2005 05:06:39
third party image
If it were parked with the levers pulled back then the clutches are probably stuck in the released position and will probably have to come out to be freed up.
Jim Presley
02-13-2005 18:38:38
So with it in any gear (try reverse as well), you pull the clutch lever back and "nothing" happens? That would indeed be odd unless something is amiss with the transmission. For both steering clutches to be completely worn out would be highly unusual. Both steering clutch levers should be in a forward position as well. When you pull back on them, is there a resistance? Sounds like it is not in gear.. Might also post this at>Link
Jim P
deweed(TX)
02-14-2005 03:25:03
 Re: td14 steering clutches in reply to Jim Presley, 02-13-2005 18:38:38
Yes it is absolutely in gear, when you let the engine clutch out it spins the pto and if you put it in 2nd 3rd or any high range you can hear the gears spinning. Is it possible for the springs to collapse? what if it had been parked with th levers pulled back? Thanks
captain_crunch
02-15-2005 19:58:06
 Re: td14 steering clutches in reply to deweed(TX), 02-14-2005 03:25:03
Me Thinks possibly Pinion or ring gear if clutches slip but unless they were tyed back they generaly stick and won't release. If pto turns trans still could also have problem as pto goes straight through. Try Red Power Mag
Brian
