JD 450 Trans
Ctorn
02-19-2005 09:34:53
Crawler has H-L-R transmission. Need Shuttle pack, clutch accumulator valve, front input shaft. Where should I look? Also does anybody know what exactly comes with shuttle pack? Any Help greatly appreciated.
Harold Brunton
02-21-2005 14:14:03
 Re: JD 450 Trans in reply to Ctorn, 02-19-2005 09:34:53
Try AIS Construction Equipment Corp. 517-321-8000,ask for used parts dept, you will talk to Mike, they have lots of stuff there,may be able to help you out,Harold
PD Mechanical
02-20-2005 06:56:55
third party image
We ahve most of the parts your looking for. Not as an assembly but as individual parts. We can also do the rebuild on your assembly if you want. Email us directly for more information.
Roy Suomi
02-20-2005 04:25:45
I don't know of anybody that sells a complete set-up of clutch packs[ other than Deere ]. I have always rebuilt the original clutch packs.If you have a tech manual , It's easier to rebuild than to actually remove and replace the clutch assembly back into the transmission case..
