Can you find parts for a HD 9
Tractractor
02-21-2005 21:24:45
Going to look at a HD 9 that is for sale. So I was wondering if parts are available for this model? I looked through the board and found mostly HD 5 6 and 10's.
Any thoughts on how well they work? It has a striat blade that is 10' wide.
Thanks
hector gemme
02-22-2005 00:57:35
 Re: Can you find parts for a HD 9 in reply to Tractractor, 02-21-2005 21:24:45
hi That a good machine and no probleme whit parts hi have some exept chaine .hector
hector gemme
02-25-2005 13:18:39
 Re: Can you find parts for a HD 9 in reply to hector gemme, 02-22-2005 00:57:35
HI I have many parts like final drive stering cluch bevel gear ,transmission,roller top and botton,idler ,sprocket ,motor parts and more .hector
coonhunter
02-25-2005 12:26:09
I learned on them 'ol dinasours. My dad was a small contractor, he had a HD 9 dozer (with complete grubber blade) and a HD 9G loader as well. Both had 471 GM diesels. You had to be an octopus to operate the loader. Weakest part on the "9" model was a small shaft (ponion ?) under a 6" + or - cover behind the top of the rear sprocket. Keeping bolts tight and shimmed correctly was a problem. P.S. Just took the last "9" parts machine to the local scrapyard. They said they needed it in China.
