I'm a newbie at this heavy equipment, so please be easy on me :)My wife's grandad left us some equipment to use on 100 acres of mountain property here in rural Virginia and I need a little help figuring out how to start it.... I'm planning on replacing the fuel filters - he was running it up until last year....should the diesel fuel still be okay? On the starting part, there are three components on the right hand side, above the foot rest - a push button for the starter, a key switch, and a push pull knob - I swear it looks like a shotgun shell - the brass part. You can either push it in or pull it out. I have no idea what it's use is. The key switch has three positions - off, on, and momentary....any idea on the momentary part is for? The fuel bowl on the right side has a lever - maybe to prime it? The only markings on the whole machine that I have seen so far is the serial number 1137 or 1157, it's kinda hard to tell... It starts up when you give it a shot of starting fluid, but won't run beyond that....
Suggestions for a dumb engineer like me? Thanks! Brian
