Obsolete tracks
IanC
02-24-2005 06:13:50
I'm lookig for a set of tracks for a Case/Davis TF1000 Super track type trencher. They are not available from Case, or Astec which is who owns the trencher line now. I've checked with Berco, and several other vendors from my copy of Contractors Hot Line. Anybody know of a source for these? The Case P/N was H575225. Take out the "nospam" to e-mail replys.
Taylor Lambert
02-27-2005 21:17:16
 Re: Obsolete tracks in reply to IanC, 02-24-2005 06:13:50
Im not sure what size your machine is but the Case Davis machines around here use Mill chain, Basically a roller chain with pads to weld onto your grousers. Ivemade a few sets for the little 4 foot wide trenchers here and a few house trailer placers. I use AR500 key stock and 1/2 by 2 plate for the pads and if I have a worn sprocket I cant take my pattern burner and cut out a new sprocket ring.
JD dozer mike
02-25-2005 18:11:03
IDEA:
maybe you can find a drive sprocket ring from jd or somthing with roughly the same radious, cut your drive sprocket ring off and weld in a replacement, then you could use a standard JD or berco track..
