price on a JD 420 crawler
tyler mostia
02-24-2005 14:14:14
hi my local dealer rented there John deere 420 crawler with a loader on it to someone after a while of useing it they called the dealer back complaning that it was missing on one cylinder considering these machines where only 2 cylinders it was barly running. the dealer said that they just havent had time to look at it they said that nothing is wrong with it except that it is missing and that they would give it to me for 2,500 is this a good deal?? and what could be wrong??
thanks
buickanddeere
02-26-2005 01:37:22
 Re: price on a JD 420 crawler in reply to tyler mostia, 02-24-2005 14:14:14
Put Autolite 216 plugs in it. Clean the dirt out of the fuel sediment bowl and clean the screen while you have the tools out. If it still misses the bushing in the distributor is likely worn letting the shaft wobble. Now point gap and timing is all over the place.
Jim in Michigan
02-24-2005 22:23:11
I loved my 420 till the final drive busted,, then it was a money pit. It was a lil power house for its size, but like all JD equipment parts are pricey,, I sold mine with teh busted final drive for 900, it had a blade on it and a "cab" Ran great and the guy actually drove it up on the trailer,, took some time loading since you could move forward 6 feet then back up 4 and then ahead again, took a while but he loaded it,,,JIm
Bernie in MA
02-24-2005 15:13:58
Sounds like a real good deal to me. I paid that for one with a #62 blade with a stuck engine. I got it loose and been using it the last 2 years.
Most likely has a fouled sparkplug or bad/loose wire. At worst a stuck valve.
