model year of HD5?
Scott B in WI
02-24-2005 18:46:00
Hi - I am looking at an HD5F with Drott shovel. s/n is 17259. What is the model year on that machine? What is the difference between HD5B and HD5F?? Thanks
JOB
02-26-2005 17:48:36
 Re: model year of HD5? in reply to Scott B in WI, 02-24-2005 18:46:00
I would say the machine you are looking at is newer than mine. I have three digits in my serial number, and I believe it was built in 1956. I would run the serial number with the engine builder and see when it was shipped from the factory. That will give you a pretty good idea when the machine was built. As for the difference between a HD5B and HD5F, I will print part of a paragraph out of a Manual. The truck frames support the main frame by the use of an equalizing spring except on the HD5F and the HD5G.These models have a rigid beam in place of the equalizing spring. If there is any difference other than that I do not know what it could be.
Scott B in WI
02-24-2005 18:53:31
Oops-that last question should be:
what is the difference between the HD5F and HD5G?
Thanks!!
Dick2
02-25-2005 04:55:36
 Re: model year of HD5? in reply to Scott B in WI, 02-24-2005 18:53:31
According to CH Wendel's book, The History of Allis Chalmers, that is a late 1952 model. With the time it took for Drott to add the shovel, it probably didn't get put into service until sometime in 1953.
