hydraulic question
double d
02-24-2005 18:49:14
I can"t find the correct forum, but maybe someone here has knowledge on this subject.Ihave an old energy brand gear pump mounted direct to the resivior on a 71 ford dump truck 1 ton. The pump gets weak after @5 loads dumped. There is no linkage or cables connected to the spool that controls the flow just a pto cable to engage the pump. Has anyone ever seen this type setup.
Bentwrench
02-24-2005 20:55:13
 Re: hydraulic question in reply to double d, 02-24-2005 18:49:14
The pump is worn and starts to leak internally when the pump and the oil warms up. The oil gets thinner and more of it bypasses between the gear teeth and pump casing.
If it is getting to be too much of a problem you will have to at least teardown the pump and put new seals in. If that doesn't work you will have to replace it.
Good Luck!
