case 450 loader tilt and dump cly seal replacement
stressfree
02-26-2005 02:47:18
looks like locking pin,spanner nut then pull out ram.whats next,does case sell that spanner wrench?
stressfree
03-10-2005 02:41:06
 Re: case 450 loader tilt and dump cly seal replace in reply to stressfree, 02-26-2005 02:47:18
my computer was down for a week,got spanner wrench for case,$100 but it has both small and large pins.case says he has 3 different seals for the dump clys.are there #s to make id simpler?
ben brown
02-28-2005 15:21:09
one thing i can tell you is i use a lot of after market parts except for seal kit for rams after market just never seem to fit quite right. i bought a spanner wrench from case industeral dealer for 80.00us good heavy wrench saved 80bucks worth of hide and fingers.
John Van Valkenburgh
02-26-2005 23:01:24
You're just having all the fun with the 450! I saw your subject line and thought "wait! my 450 needs that too"!
I've been thinking about having a local hydraulic service center rebuild the cylinders for me. Gonna stop by there and see what they charge. I'm also not positive that the sinking problem is not in the control (spool) valve. Could be a combination of both.
Still involved with the engine rebuild at the moment. Got the 1000lb front weight/guard off and got the bolts out of the oil pan, but the pan is stuck tight. Already gettin tired of working underneath the machine and getting crud in my eyes everytime I move around.
I've seen the cylinder wrench you talk about on eBay many times. Been tempted to get one for the heck of it.
Good luck with your cylinders and let me know how it goes. Looks like I'm next in line for the same thing....
John
1968 Case 450
stressfree
02-27-2005 05:51:31
 Re: case 450 loader tilt and dump cly seal replace in reply to John Van Valkenburgh, 02-26-2005 23:01:24
hi john,lets face it if we have to go to the shop all the time we might of get someone to do our clearing.working on my bucket i went to start it to lift the bucket and bendix quit.1/2 hour to pull starter off and apart.got a new bendix and installed the starter.how would i take that to a shop? maybe the starter.once i rebuild the cly ill be able to teach the tips and trips.now if you want to be cleaver try rebuilding a bucket thats been abused.i had to cut out the bottom.150 pounds of welding rods,2 air,1 gas,cutting edge,shanks and teeth,3/8" plate,1/4" plate and runners,$75 in gas so far,over 40 man hours,porto power and 20 pound sledge a cly is a walk in the park.after that i need a nap.big toys big tools.
marlowe
02-26-2005 11:08:17
DON'T go to case for seals or you will have more in the rams then the 450 is worth call baum hyd. 1-800-228-9222 they will fix you up. wrench EBAY or use a small chain wrench works good but pin wrench is best
stressfree
02-28-2005 03:29:09
 Re: case 450 loader tilt and dump cly seal replace in reply to marlowe, 02-26-2005 11:08:17
found wrench on ebay.used loader to plow snow.they call for 12" more.hate snow.oh also burned up a 4" grinder and ruined a air chiesel.just some useless imformation.
george md
02-26-2005 06:49:58
OTC makes the adjustable pin spanner.
( sometimes called the overpriced tool company)
george
David in SC
02-26-2005 03:43:39
Stressfree,
Try this link.
Link
If that does not work, go to ebay home page and type in Case spanner wrench.
Ends soon, very soon.
Not the same company I was thinking about.
David in SC
David in SC
02-26-2005 03:36:28
Stressfree,
If you look around on ebay, there is usually one for sale. Some company makes them (I guess) and sells them specifically for Case machines. I do not know how much they usually bring, and if that is good or not. I think it is the same company that also makes other Case aftermarket parts like track adjusters, adjuster rods, etc. I bought an adjuster rod from them last year. As info. I have a very reasonable Case Industrial dealer nearby. I took all of my cylinders to him and the average cost to rebuild was under $30 each. And if you get them in early you get them back around lunch. To me that was better than trying to do myself as I do not have a big vise or spanner wrench.
Good luck whichever route you take.
David in SC
stressfree
02-26-2005 16:02:53
 Re: case 450 loader tilt and dump cly seal replace in reply to David in SC, 02-26-2005 03:36:28
the mining company i work for deals with highway equipment.i can get the parts thru them and just work some overtime to pay for them.i do maintance work all day so rebuilding the cly is just another job.the parts book says something about a id ring? ok once i get the ram out any tricks on installing the seal? i will check out ebay when i get off here.also theres a backhoe for the 450.325 miles away.
