IH crawler tractor model 340k3
dave griffin
03-04-2005 14:08:17
looking for info on this tractor.Particularly the electrical system.Is it 6 or 12 volt?
model 340k3
serial no. A1055
manufacturer Drott
manufactured 1958 or later
Oldfarmboy Jim
03-07-2005 20:54:27
 Re: IH crawler tractor model 340k3 in reply to dave griffin, 03-04-2005 14:08:17
To answer your question, I just did a little more digging in the parts catalog for the 340 series crawlers. The diesels (TD340, TD340A) and the later gas T340A were 12 volt. The earlier gas models, T340, up to ser. no. 5395 were 6 volt. All used DELCO-REMY gen., strtr., and reg. Hope this helps you out.
Dave Griffin
03-08-2005 10:26:10
 Re: IH crawler tractor model 340k3 in reply to Oldfarmboy Jim, 03-07-2005 20:54:27
Thanks to all who have responded.It has really helped me out.
Dave G.
Oldfarmboy Jim
03-06-2005 21:42:30
By now you figured out that Drott made the loader, not the crawler. You've got a T 340 if it's gas or a TD 340 if diesel. The 340A models start with ser. no.5396 and up. There should be a mfgr's tag on the right top of the bellhousing, probably painted over. The A1055 ser. no. refers to your model 340k3 loader, not the tractor. I''ve got a TD 340 ser. no. 4001. Nice little machine, I enjoy working with it. Good luck, Jim
Charlie
03-05-2005 13:36:52
It was 6 volt through serial number 5395.
wilko
03-04-2005 20:33:54
There should be small tags riveted to the starter and generator that provide ser. # and, usually, the voltage of the unit. If no tag, look for stamped info. With a ser. #, a parts store can tell you the voltage.
wilko
03-04-2005 20:28:58
I have a td5, which is the predecessor to the 340. It has a 12 volt system.
bobdozer
03-04-2005 15:57:33
This serial number would be 6 volt
dave griffin
03-04-2005 16:23:53
 Re: IH crawler tractor model 340k3 in reply to bobdozer, 03-04-2005 15:57:33
thanks for the info.
regards,
dave g.
hector gemme
03-04-2005 15:29:59
HI I had one 340 and he was 12volts HECTOR
dave griffin
03-04-2005 16:37:08
 Re: IH crawler tractor model 340k3 in reply to hector gemme, 03-04-2005 15:29:59
thanks for the info
