JD 40C hydraulics
Bret4207
03-05-2005 06:52:18
I have a 40C with the front blade, single lift cylinder, and 3 PT hitch. I have an ancient Deere 2 spool valve that only works on 1 side. It also leaks like crazy and I've about had it with this one. I'm looking for a 2 spool vlave body and see Nothern Hydraulics has a couple of items. I basicly need to know if I have to order an open or closed center control. I can never remember which is which.
JDAOS
03-07-2005 08:04:01
 Re: JD 40C hydraulics in reply to Bret4207, 03-05-2005 06:52:18
I recently picked up a 40C with aftermarket three point. It would be interesting to see a picture of yours to compare with mine. Mine has some 420C 3 pt features and some shop built components. I am posting a picture of mine in the tractor photo gallery.
originsal possum
03-05-2005 19:52:04
Open Center. You don't want any hydraulic resistance unless you are activating a spool.
buickanddeere
03-06-2005 13:30:30
 Re: JD 40C hydraulics in reply to originsal possum, 03-05-2005 19:52:04
Set the relief at 1200psi max.
Bret4207
03-06-2005 05:12:50
Thanks Possum. I kind of figured that was the answer but greater minds than mine exist here!
