jd 1010 I NEED HELP!!!!!!!!!
mborrasca
03-07-2005 18:18:08
trying to remove tracks to replace steering clutches....can't remove master pin!!!!!it moved about 1/2 inch i tried heat and i tried heat then quench it with 10 gallons of water and hitting it with air hammer...nothing is working i have the pin on back sprocket just past half way and have bottle jack on bottom to lift weight and have track blocked on either side of idler....any ideas thanks
stevebogusta
03-08-2005 19:11:50
 Re: jd 1010 I NEED HELP!!!!!!!!! in reply to mborrasca, 03-07-2005 18:18:08
I would torch it and just buy a new one.
original possum
03-08-2005 15:56:17
Look in the hole that the pin drove out of. If the two parts(the two links that join at that point)are even, making the hole nice and round, then you just need more help to hit it. If you see that the hole is not round because the links are already moving apart then you are hung on a shoulder worn into the pin. If you are hung, give the track more slack or get a pin with a diameter closer to the master pin in that hole to take up the slack.
jdemaris
03-07-2005 19:36:05
If you've got the original master pins they're headed and only come out one way - but I assume you either know that or have a newer headless master-pin. I've had to torch a few out when splitting a track by myself. But, if you've got few other people to help you, I've never had one yet that wouldn't come out when hit correctly. You need someone to hold a large sledge against one side (to back it up), while another holds a starter pin of some sort in place against the head of the pin you're driving on - something heavy with a diameter just a little smaller than the master-pin, and the third person swinging a sledge against it. We used to keep two homemade tools in the shop for starting pins. The first starter has a handle and kind of looked like a pick-axe - and was sharpened enough at the end that it could drive a pin a small amount. Once the pin started to move, we used a second starter/driver with a handle on it with a pin at the end just a little smaller in diameter than the master-pin.
mborrasca
03-08-2005 09:58:29
 Re: jd 1010 I NEED HELP!!!!!!!!! in reply to jdemaris, 03-07-2005 19:36:05
thanks for info i will try with dad later i was trying to do it myself last night...the pins have a head on 1 side facing out away from machine and with a winch on rear its hard to get a good swing at it..can"t get good leverage laying down...
Clint Goodson
03-28-2005 18:24:41
 Re: jd 1010 I NEED HELP!!!!!!!!! in reply to mborrasca, 03-08-2005 09:58:29
If you are still having trouble removing master pin, rotate track until master pin is middle way around front idler. If tractor has a blade than you will need to rotate toward lower portion of idler. I use a 3/4 in dia. long drift. and a sixteen pound sledge to drive out pin. It usually takes two people to do this. The drift I use has handle on it. These can be purchased through Warren Tools.
mborrasca
03-09-2005 08:10:35
finally got it last night!!!!!dad came over and kept the torch on it and i hit it with the air hammer and it shot right out....the rest of the job was no problem removing the final drive..inside it was a mess! the inside was full of debris the clutches were just seized up with rust.after i clean everything up is there anything that i can use to coat the inside to prevent the rust and keep everything moving free without worrying about getting it on clutches...i noticed some play or chuck when i grabbed the sprocket no signs of leaking just wondering if i need new bushings or bearings???over the years someone has been in the finals before and definatly rigged things up you might say....any advice?????thanks again for the help
