JD450B
Zak Ernst
03-07-2005 20:05:32
i just purchased a jd450b and when you pull the right stick it does not turn right is there an adjustment or are the right clutch/brake bad and if there is an adjustment how do you do it thanks
jtilson
03-08-2005 05:50:45
 Re: JD450B in reply to Zak Ernst, 03-07-2005 20:05:32
First, go to the little "search" block above and type in JD450B steering clutches or such phrases and see prior discussions.
You probably will need instructions from a manual if you dont find it there. Course there are a lot of more helpful guys than I here so they may help you too.
I have an old 450 but the B is a little different I think.
