Mag Substitute For Allis-Chalmers Model M?
StuckyRusty
03-10-2005 16:14:31
We have an early M. Serial number is missing but I believe it to be an early model due to the gas startup tank. The mag is weak and doesn't spark every time. I plan to remove it and check for simple things like points and dirt. If for some reason repair takes a while, would a mag from a WD work? The mag on it now is a Fairbanks-Morse RV4B.
Pete in Cal
03-10-2005 18:27:44
 Re: Mag Substitute For Allis-Chalmers Model M? in reply to StuckyRusty, 03-10-2005 16:14:31
The serial # is stamped on top of the transmission cover to the right of the gear shift. Engine ser. # is on the side of the engine block on a flat spot, don't have the book available right now and can't remember which side the engine it is on. Can't say about the mag swap. Pete
StuckRusty
03-18-2005 16:44:26
 Re: Mag Substitute For Allis-Chalmers Model M? in reply to Pete in Cal, 03-10-2005 18:27:44
Thanks for the info on the location of the serial#. It reads "WM 6666" making it a 1937 model.
dej(JED)
03-14-2005 10:32:23
I have an early Model M also and it uses the same mag as the WD. A Farmall Mag has the same lag time. Also a distributor from a Farmall or AC will also work if you ad a battery and the coil.
Dave Brennan
03-12-2005 14:23:02
I have some AC "K" models of the same vintage, They have Fairbanks Morris J series mags on them. I know that type RV mag is tough to get parts for. Especially the condensers!
