case 580 super k
d. schrems
03-10-2005 16:17:01
my 4 wheel drive case backhoe needs to have the front axle ball joints replaced. is this something a simple person like me could handle?
Burton
03-14-2005 22:17:21
 Re: case 580 super k in reply to d. schrems, 03-10-2005 16:17:01
I did my SK axle and it can be a pain, but do-able. Use the BF pipe wrench you can find (w/cheater) and apply heat to the swivel case and twist pins while spraying PB blaster or equal between pin and housing. When you re-assemble, wire wheel the pins and inside of the housing and coat pin with anti-sieze (should slip right in). To remove the races in the axle I ran a bead of weld on the bearing suface of the race ( shrunk it)and it pryed out pretty easy. Hope this helps.
AJK
03-12-2005 16:43:02
It can be a right SOB to get the old pins to come out,first try removing the shims from under the triangular plates on the pins,undo the three bolts on each pin and get the shims out,you may need to knock the pins home with a sledge hammer,(protect the grease nipples)I have posted a picture from the parts book so you can see the setup,its at the link below
AJ
