Fiat-Allis FL10E(turbo problems)
Jbull
03-10-2005 20:03:25
My Turbo recently took a dump.(Bad, the shaft broke and the engine ingested a few turbine fins).So I took one off of my parts machine(FL145)and put on it. It runs fine now, but when I get close and listen next to the precleaner I can hear a flutter. Could that be a bent intake valve? I have not checked the temperature at the exhaust manifold yet to see if I have a cold cylinder.
Bob/Ont
03-10-2005 20:36:20
 Re: Fiat-Allis FL10E(turbo problems) in reply to Jbull, 03-10-2005 20:03:25
If you have a bad valve you should hear a mis and see a white puff of unburned fuel in the exhaust.
Later Bob
Jbull
03-10-2005 21:03:05
 Re: Fiat-Allis FL10E(turbo problems) in reply to Bob/Ont, 03-10-2005 20:36:20
What could that flutter Be? it kind of sounds like when (only 1) one piston is coming up in the exhaust stroke, its pushing a small amount of air back into the air breather. Thank you!
dsldr
03-29-2005 16:37:11
 Re: Fiat-Allis FL10E(turbo problems) in reply to Jbull, 03-10-2005 21:03:05
Remove the pipe between the turbo and the intake manifold. Run it at idle--if it has a bent valve or an intake valve that is not quite closed you will hear it.
