JD Track loader
Van in AR
03-15-2005 09:20:28
I have a JD 755 track loader that is fully hydrostatic, the problem is that the left track does not lock up or turn back wards in a turn if the pedal is fully pushed down. The right side works correctly, Does anyone have a idea where I should look for this problem? Thanks to all.
Van
Jonathan in MA
03-15-2005 15:30:02
 Re: JD Track loader in reply to Van in AR, 03-15-2005 09:20:28
Lift up the floor board and study what linkage does what when steering. See if the lever for left track and the right track on the control valve, move equally. If its hard to tell, remove the steering linkage at that control valve under the floor. you can operate the small steering levers on the valve by hand and see if it will then counter-rotate. if it does, then there must be a linkage issue between the pedal and the control valve. If that doesn't change anything, report back ...
