case 450 crawler roller replacement
Phil H.
03-18-2005 06:47:37
Hi, I need to replace 2 track rollers, on my case 450 crawler. They are the first lower rollers on both sides, the one closest to the track sprocket. Do I need to split the track, or can I get enough slack in the track to replace just the first roller. If I need to split the track, can I drive out the master pin with a sledge? Not looking forward to spliting the track, but Oh well any help is appreciated.
hector gemme
03-18-2005 09:12:02
 Re: case 450 crawler roller replacement in reply to Phil H., 03-18-2005 06:47:37
HI No you dont need to split the track let take out grasse off cylindre and you have place to work.hector
Phil H
03-18-2005 10:16:56
 Re: case 450 crawler roller replacement in reply to hector gemme, 03-18-2005 09:12:02
Thanks Hector, I"m going to try that out, and I will block up the machine so the slack will hang down as far as it can.
stressfree
03-19-2005 03:48:02
 Re: case 450 crawler roller replacement in reply to Phil H, 03-18-2005 10:16:56
ebay is selling a new one for $60.type in case 450 in buiness and industrial
Phil H
03-19-2005 04:39:03
 Re: case 450 crawler roller replacement in reply to stressfree, 03-19-2005 03:48:02
Thanks, I contacted the seller.
stressfree
03-19-2005 15:29:19
 Re: case 450 crawler roller replacement in reply to Phil H, 03-19-2005 04:39:03
glad to be of service.
