John, Field failures is a distinct possibility. The difference in oil flow however is the middle hole gets its pressure directly from the mains which means there is going to be a lot of pressure going up to the rocker train. The rear hole comes from the cam bearing which has reduced pressure. I'm betting that over oiling was as much a problem as anything else. To much oil on top of the head can lead to oil getting in through the valve guides when the seals are worn and lead to excessive smoking. Just a thought. As far as the sleeves, I took my block to a machine shop and they pulled the sleeves for me. I had been hoping for a budget rebuild where I could use the original sleeves and pistons. Turned out all of those parts were worn beyond hope. I ended up buying a real nice set of used pistons and sleeves for $140. Definitely cheaper than the new set and they cleaned up just fine. I bought the backhoe with a known knocking sound from the engine. We had been hoping for just a hole in one of the pistons, unfortunately it ended up being a spun rod bearing which trashed both the rod and the crank. Finding a replacement crank wasn't as hard as I thought it was going to be. So I now have a nice freshly turned crank at .010 and a decent replacement rod. So much for the budget rebuild! I'm not sure how you do the crank bearings with the engine in the frame. These bearings have some pretty hefty side shoulders unlike normal car bearings which are just curved half discs. I'm betting you won't get enough deflection in the crank to slide the top bearing out. Be interesting to see how you fare on that one. I'm going to have my injectors rebuilt. I've been told the pencil type (later) can't be rebuilt but the ones like mine can. I think rebuilding or replacing is one of the better things you can do for a diesel rebuild. Thats interesting that your oil pan is cast, mine is sheet metal. Maybe thats one of the lessons learned over the years. It might have been to easy to puncture a sheet metal pan from tree limbs, etc. Hope your rebuild works out ok! Brad
