Cat D4 Pony Motor Question
Greg Lasher
03-27-2005 18:05:34
The Pony motor on my D4 has a newer replacemnt mag (a wico?). I took it out to repair it but now I'm wondering how to time it again. Is there an inspection plate behind the mag that you can see to line up the timing marks? Thanks in advance
hector gemme
03-28-2005 03:49:59
 Re: Cat D4 Pony Motor Question in reply to Greg Lasher, 03-27-2005 18:05:34
HI I have a service manuel and use parts for d4 if you need some parts I COULD SEND YOU PAGES MAGNETO SERVICE WHIT THANK.HECTOR
OlCatBob
03-27-2005 20:26:05
Greg, there is a pipe plug on the back side, remove it look for "M" and align marks. take left spark plug out, put thumb on plug hole to feel for compression, and for said M. you need to take cap off mag to see which plug is firing, but it"s very simple.
Bob
Greg Lahser
03-28-2005 02:03:44
 Re: Cat D4 Pony Motor Question in reply to OlCatBob, 03-27-2005 20:26:05
thank you Bob - Just one more question can you see do this with the pony in the tractor -- looks like the mag is smack up agains the head of the main eninge?
Greg
OlCatBob
03-30-2005 06:03:54
 Re: Cat D4 Pony Motor Question in reply to Greg Lahser, 03-28-2005 02:03:44
Greg, I don't believe the valve cover needs to be removed from the main engine, but it may make it a littler easier to accomplish. It's really very easy to do, as there is only two ways it can go as long as the "M"s match. At worst it will be 180 out, just swap the plug wires at the cap.
Bob
