hot water pressure washer comments wanted
bob up north
03-27-2005 19:25:22
I am a small time dirt contractor operator.
Never had a pressure washer before, am asking what to look for and what minimal size I really need. Looking at a hot water diesel fired burner unit with 2.6 GPM and 2,000 PSI. Honda gas engine. Down line after pump low pressure soap injector. complete unit on a cart. Would this hot water pressure washer work cleaning oil and grease off the heavy equipment and clay off the dozer tracks? Would sure appreciate some input from you all.
marlowe
03-27-2005 21:11:35
 Re: hot water pressure washer comments wanted in reply to bob up north, 03-27-2005 19:25:22
they don't do a real fast job on the clay just NOT enuff water flow i use a 250 gpm pump at 80 to 100 psi and old fire hose and nossel [from ebay] and it will clean the tuffest red clay out in just minn. NEED BIG water supply i use my pond wash all my heavy eq. this way [cats hoes dumps ] only way for me
