International 175B crawler
Garym
03-28-2005 06:13:47
Would someone know the weight, with a blade, of an International 175 B crawler? Also how to adjust the track tensioners? Believed to be a 1978 model. Thankyou, Gary
seann
03-28-2005 09:16:09
 Re: International 175B crawler in reply to Garym, 03-28-2005 06:13:47
The 175C was available in '78 (not the B). And I assume you are referring to the loader? You mention a blade which implies you're talking about a dozer? Dozers had "TD" designations (TD9,TD15,TD35 etc)
Anyway here are the weights of a 78-79 175C loader:
GP bucket: 30,655 lbs
Quarry (w/weld on shanks): 30,925 lbs
4-1 Bucket: 31,900 lbs
chas p
07-08-2005 19:32:36
 Re: International 175B crawler in reply to seann, 03-28-2005 09:16:09
I reviewed your posting and was hopeful that you could give me more information on the 175c. I have recently acquired one that had been abandoned and plan to use the same for farm purposes. Could you tell me if the numbers you referred to are the gross vehicle weight and what is the horsepower rating of this machine? I am also curious if I will have difficulty in finding parts when needed.
Anything you could advise me would be greatfully appreciated.
Charlie
hector gemme
03-28-2005 09:11:40
HI I have a 175b and the weight should be 14 tonnes and for adjust the track look being the idle on the fork a small plate ,take off the srew and you will find the valve.hector
don cartwright
12-26-2006 19:16:11
 Re: International 175B crawler in reply to hector gemme, 03-28-2005 09:11:40
brake ajustment
