D4 rail specs
JMS/MN
03-28-2005 15:18:47
Can anyone tell me the 'new' and junk specs for the rails on a D4? Also any info on idler tightener dimension, other wear indicators? TIA
MSM
03-28-2005 17:18:09
 Re: D4 rail specs in reply to JMS/MN, 03-28-2005 15:18:47
You might be better off getting a track shop to come check it.There are measurements for internal pin wear,external bushing wear,idler wear,roller wear,rail height,idler and roller bearing condition,sprocket wear and alignment,pad condition and growser height. These measurements differ from series to series of tractor,dry pin or SALT tracks,as well as undercarriage manufacturers (Cat,Berco,Itrack etc.)Most shops charge a nominal fee,and usually waive it if they do the work.They can tell you if you just need a P&B turn and a set of sprocket segments or rings or other work that will make the undercarriage last.
hector gemme
03-28-2005 16:03:15
HI you vice the big nut being the hoke idler on the spring screw and check the rail whit a pitch bar she need 1½ TO 2 INCH SLAC.Ihave some use d4 parts if you need more information send me a é-mail.hector
