d47u
catd4
03-30-2005 19:30:53
I'am going to look at a d4 7u on saterday is there anything I should look out for on this model dozer? thank you
clint goodson
04-01-2005 20:18:56
 Re: d47u in reply to catd4, 03-30-2005 19:30:53
check that the pony motor is not stuck, make sure that the steering clutchs release. check radiator for oil in the coolant. if machine has been setting for some time the precombustion chambers can leak, if machine will start check for air bubbles in radiator.
hector gemme
03-30-2005 22:23:08
HI Check the boushing rail and sprocket and try the stering cluch are oke.HECTOR
