Looking for engine parts for TD 14
Mario
04-01-2005 19:03:15
Looking for the following parts:
Good Cylinder Head, casting #306224R3
Also looking for Crankshaft with casting #
53401D.
956-287-8607 (Home)
956-793-1563 (Cell)
hector gemme
04-02-2005 02:39:35
 Re: Looking for engine parts for TD 14 in reply to Mario, 04-01-2005 19:03:15
HI I have some td 14 parts.
David Rychener
04-18-2005 09:17:47
 Re: Looking for engine parts for TD 14 in reply to hector gemme, 04-02-2005 02:39:35
I also need parts. I've got too much invested to stop now.
I need one TD-14 piston head. I don't need the rod. I also need the rings, a compression sleeve and main and rod bearings. Any ideas on where to get these for the best price?
I also need the left-hand turning clutches. . all the plates (28 of them, I believe). I assume they're the same as the right side. I'm hoping my drums are OK, although the clutch plates are so rusted to the drum and hub, I don't know if I can get them out without damaging the hub. Because of a plugged drain hole, they sat in water for 10 years and are like welded with rust to each other as well the hub. I've soaked them in everything I can think of to free them up.
Any ideas???
In too deep,
David
hector gemme
04-22-2005 02:49:17
 Re: Looking for engine parts for TD 14 in reply to David Rychener, 04-18-2005 09:17:47
HI I have some plate and disc and drum for td14.
hector gemme
04-18-2005 09:49:02
HI I have some use piston and sleeve and more for td 14.HECTOR
